6XAs Battery Charging
I recently purchased a 6XAs and did the non-male thing and read the manual. The manual talks about the importance of preventing battery "memory." It also states "You can cycle your batteries with a commercial cycling unit..." Can this be done without removing the batteries from the transmitter case? I was under the impression that this transmitter has a diode which would prevent cycling. Is it possible that this transmitter is now being manufactured with a "polyswitch"? Thanks.
Jack
Jack
