Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
Servo Jitters
Old 11-11-2003 | 05:28 AM
Default Servo Jitters
Bax,
Servos over my plane jiiters on two conditions :
1. When putting or relesing the glow booster.
2. When plane is beyond a ground range of 50 Feet with antenna collapsed, FM modulation, model 3 feet above the ground.
Kindly suggest what to do.
Sharad
( In flying there is actually no problem at all)
Old 11-11-2003 | 03:45 PM
Default RE: Servo Jitters
Hi Sharad,
It sounds as though you are getting some interference from the Glow Booster you might try using a filter on your servo leads. Also the the range problem my be due to the area that you are doing the range check in....anything such as a metal fence, a wall that is close to you, or metal poles close to you, anything that would reflect the signal back. Try a range test in a different area to see how this does for you.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Also you may want to check our Website at (http://www.futaba-rc.com)
Old 11-12-2003 | 04:28 AM
Thanks Krysta,
But they are very expensive as i will have to go on all the servos I guess. But let suppose I do not use them at all would there be any kind of a problem?
Sharad
