Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
FP-R127DF Receivers
Old 11-20-2003 | 06:06 AM
Default FP-R127DF Receivers
I have two FP-R127DF receivers with no crystals and no stickers on them.
How can I tell if they are Hi or Low band?
Old 04-16-2004 | 11:57 AM
EchoBravo's Avatar
My Feedback: (220)
Default RE: FP-R127DF Receivers
Rutski,
Check inside the crystal socket, if you see a red dot it's a high band (36-60). If not, it's a low (11-35).
Old 04-16-2004 | 09:05 PM
My Feedback: (16)
DO you have a picture of this?
I looked in my CH38 receivers and didn't see a dot
ORIGINAL: sigflier
Rutski,
Old 04-23-2004 | 10:19 AM
Hi Geistware,
You should see a red dot on the PC board of your R127DF or on the coil of your R148DF, R148DP, etc receiver if it is high band.
If you are not seeing one and you are sure that it is high band, it may be that it was originally low band but retuned to high.
Thanks, Krysta
Old 09-25-2004 | 04:16 PM
hello all,
i got a Futaba FP-R127DF flight pack with a 7 channel reciever and there was no manual so i dont know which numbers go to which servos, i have two alerion servos, a rudder, elevator and a throttle servos too, help me someone! Its the last thing i have to do before i can fly my hanger 9 twist. thanks
scott
Old 09-25-2004 | 05:32 PM
Dan767's Avatar
My Feedback: (19)
1-Aileron, 2-Elevator, 3-Throttle, 4-Rudder. You can "Y" the ailerons or you can mix them on 1&7 using flaperons set to 100%
Old 09-12-2008 | 12:25 AM
anyone selling a r127df I need 1 if so please send a e mail to [email protected]
