Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
Programming an 8UAFS
Old 11-29-2003 | 11:36 PM
BCoston's Avatar
My Feedback: (7)
Default Programming an 8UAFS
I have two questions.
I would like to program a speed brake using channel 6 (flaps) to activate using switch "C". I would like "up" being zero degrees, center 75 degrees, and down be 90 degrees deflection. I'm not sure how to get full servo travel without the knob?
My second question is how to program nose wheel steering using channel 4 and a rudder servo using channel 7 or 8. I would like the nose wheel steering to deactivate when the landing gear is retracted.
Brian
Old 12-03-2003 | 04:44 PM
Bax
Default RE: Programming an 8UAFS
For your flaps, please see this thread: http://www.rcuniverse.com/forum/m_11...tm.htm#1146088
As far as your nosegear is concerned, put your rudder servo on channel 4 as normal. Program the steering servo channel (7 or 8) on a PMIX to be activated by the retract switch so that the mixer is on when the retract switch is in the gear-extended position. Your mixer would have channel 4 as master and the steering servo channel as slave.
