Servo s3050/s3151
I would like to know more info on the new futaba servo, model number S3050 and S3151. I would like the speed, torque, dimensions and weight, I look on our web site and tower hobbies web site and I cannot get any info. Kelly
HI kelly,
The S3050 is a Digital servo with metal gears and the specs are:
Dimensions: 1.6x.8x1.5" (40.6x20x38mm)
Weight: 1.6 oz (45.4g)
Speed@6V: .16sec/60deg
Torque@6V: 90.2 oz/in
The S3151 is a Digital servo with metal gears and the specs are:
Dimensions: 1.6x.8x1.4" (40.4x19.8.36mm0
Weight: 1.5 oz (42g)
[email protected]: .21sec/60deg
[email protected]: 43.0 oz/in
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Also you may want to check our Website at (http://www.futaba-rc.com)
Sincerely,
Krysta
Can we run the s3050 and the s9152 at 4.8volts, if so what are the specs. at 4.8v. And I would like to know the specs of the s9153. Thank you
Would you be able to confirm that the S3151 is a double ball bearing servo as mentioned in the Tower description of the servo. I am also puzzled as you mention that this is a metal gears servo while the replacement servo gears in the online Tower catalogue item no. LXH414 shows plastic gears which are common between S3151 and S148. Please clarify if you can
Cheers!!
Cheers!!
ORIGINAL: Krysta
HI kelly,
Sincerely,
Krysta
HI kelly,
Sincerely,
Krysta
Hi guys,
Forgive me please the S3151 DOES contain nylon gears. But it is in fact Dual Ball Bearinged.
The S3050 and S9152s' can be run at 4.8V but it is not recommended to do so.
Here are the specs on the S9153:
Speed: 0.15 sec/60 degrees @ 6V
Torque: 208 oz/in @ 6V ( 15 kg/cm )
Weight: 3 oz (85g)
Length: 1.91" (48.6mm) case only
Length: 2.54" (64.6mm) including mounting tabs
Width: 0.99" (25.2mm)
Height: 1.56" (39.7mm)
Sincerely,
Krysta
Weight: 3 oz (85g)
Sincerely,
Krysta
