Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
Polyswitch for 9Z?
Old 12-08-2003 | 05:51 PM
My Feedback: (35)
Default Polyswitch for 9Z?
I was wonderding if the polyswitch which replaces the diode in some Futaba radios can be installed in the 9Z. I would like to peak charge and cycle without removing the battery, thanks.
Ralph
Old 12-09-2003 | 10:24 AM
Default RE: Polyswitch for 9Z?
Hi Ralph,
No, the 9Z cannot use the Polyswitch, as the 9Z's battery is self contained. What you are wanting is the Battery Discharge Connector, HSP78050, which you can purchase through your local hobby store. This connects to the battery itself and allows you to cycle the battery outside of the transmitter.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Also you may want to check our Website at (http://www.futaba-rc.com)
