9C + Spirit 100 & 550 Can
Looking for advice here. I am just about to finish building a Spirit 100 kit. Current config is with a 6 servo install for full flap control.
My problem is what is the best way to config this in the 9C. If there was no MOTOR, simple a Glider 2 flap. I would like to drive the motor via the throttle but have it mastered of a switch so I can start and stop it as needed.. A mix perhaps???
Option 2 is to set it up as an Acrobatic but I have a feeling I will compromise on the Glider premix's...
Appreciate any thoughts and guidance
If you use the throttle channel to activate your motor in one of the glider presets, you'll have problems with airbrake/butterfly, since that operates off of the throttle stick. Your best bet would be to operate the throttle off one of the aux channels, and set that aux channel to the left-hand slider. You do that in the AUX menu.
To operate the throttle with a switch, use a free PMIX and select offset as the master, and the channel operating the throttle as the slave. Just adjust it so that when the mix is "ON", the motor's turned off. When the mix is "OFF", the slider will control the throttle.
