RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
Bogging down
Old 07-21-2005 | 11:43 PM
D0G
Default Bogging down
Simple Question. When I accelerate my Nitro Evader it bogs down B4 it takes off. When at high speeds it sputters once in a while but runs great most the time. Warm or cold it seems to....lag or bog down when I give it lots or little throttle. I havent messed with the Low speed screw much at all from break in. I have adjusted the High speed to what i feel is a good place. But I can hardly spin the wheels or even lift them off the ground. I know its not the Slipper or the Diff as you can hear the engine bog itself almost to a stall.
Suggestions would be most helpful
Old 07-21-2005 | 11:55 PM
Skullbasher's Avatar
Default RE: Bogging down
Probably lean on the HSN, try richening it a little bit.
Old 07-22-2005 | 12:16 AM
Banned
first get ur hsn tuned then lowspeed
ur low speed is out of tune. if ur runnin hot richin the low speed if ur runnin cool lean the low speed. and im talkin tiny adjustments on the lsn. and after u get the low speed good u might have to adjust the idle
Old 07-22-2005 | 06:27 AM
gerwen's Avatar
Tune your high speed needle properly, then work on the lsn.
ORIGINAL: Frost_
The issue of tuning comes up frequently, so I thought I'd modify a piece I did about big-block tuning that has been floating around the Savage forum. A variation of this was told to me a while back.
Guys, FORGET about asking what other's settings are, once you do this a few times you can take any old strange engine (meaning one that is working, but unfamiliar to you) and start from nothing, that is, knowing NO settings and get the most out of it.
For some reason even in the mags when they tell you "how to tune", they have you pinching the fuel line and timing the result in seconds to "set" your LSN. No doubt this is a good way to get in the ballpark, but it is FAR from precise.
The following will asume that you have your top-end tuned to a decent temp. range for your normal style of driving. If you AREN'T running lean (stuttering, you hear it, you know what it is) you can very safely tune the top-end to 250-260 with no reduced life (AGAIN this is if it isn't going LEAN). This temp. is a range for many, but not all smallblocks. Some like to be run even hotter (TRX 2.5 makes it's best power at 275F +) Once you get the top-end set here is how to really make it take off fast. If you are heavy-fingered this may be better for the pavement. Before you begin tuning the LSn, get the engine up to operating temperature first.
1. Since off the line "snap" can be given or taken away by being lean OR rich on the LSN the first move is a guess (well it won't be after you get a feel for it, but this will get you going quickly)...
2. Pull the truck up in front of you and let it idle for 8 seconds. Then pull the trigger to WOT... Did it scream and take off? If no:
3. You have to go one way or the other... choose richer or leaner (suprisingly to many beginners, off the line stutters can be caused by too lean conditions just as easily as too rich) and turn the LSN in that direction 1/16th of a turn. Make a short pass at medium to high throttle and return the truck to in front of you.
4. Let it idle 8 seconds and floor the throttle. Did it take off better or worse? If better, turn it a 1/16 in the same direction, if it got worse, turn it 1/8th the OPPOSITE way. Either direction you started in, now you will be going one way based on whether it got better or not... either richer or leaner.
5. Make another short pass at medium to full throttle (AFTER you made the change to the LSN) and return the truck to you. Let it idle 8 seconds and floor it. Is it still getting better? If so, continue to lean or richen using the pass/idle 8 seconds method until you lose preformance and back up a step...
If your temps are in range this is how to quickly get your truck to "explode" off of the line... Always make the pass to clear out the engine and then let it idle 8 seconds. The idling will allow it to either lean out or load up, depending on which way the current settings are off... Get the hang of this and your truck can really take off. If you end up leaning the LSN out excessively make sure to keep an eye on temps, your top end needle may need a bit of enrichment.
Copy this text and print it out if you need. Once you have done this you will realize how you are affecting positive change and it only gets easier.
