RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
OS 12 TZ Help !!!!!!
Old 07-24-2005 | 10:17 AM
Default OS 12 TZ Help !!!!!!
I just bought the OSv12 TZ 5 port . I was going to put it on my losi XXX NT . When I went to put the fly wheel on the engine it on went to the threads and would not go any further.
There is only one listing for the 5 port and its 12TZ (p) T5 .What does the (P) stand for ? Plain ? ????????
Did I get the wrong motor ? Do they make a 5 port for a truck ?
Please help !!!!
Old 07-24-2005 | 10:20 AM
monsterpede360's Avatar
Default RE: OS 12 TZ Help !!!!!!
man i think you have the right engine just have to do some custom fabrication
Old 07-24-2005 | 10:34 AM
The crank shaft on the motor is long. I have cut cranks off before but it looks like if I cut this one it will still be to long. If I drill out the fly wheel to go on then the clutch nut will not tighten up to the fly wheel.
Old 07-24-2005 | 10:40 AM
These picture will show my problems.
ID:	300847   Click image for larger version
Old 07-24-2005 | 11:48 AM
I think you got the one with the wrong crankshaft for the Losi NT. That one works with a touring car.
Ed M.
Old 07-24-2005 | 12:34 PM
The (p) meens Pilot shaft. That is the wrong crankshaft for the XXX-NT, and it doesn't come with the right shaft for the XXX-NT because it is designed for onroad racing. A 5 port isn't even race leagal for stadium truck racing.
Old 07-24-2005 | 12:58 PM
can't he use a flywheel and clutch from a jato or T-maxx? There is always a way to make it work.
Old 07-24-2005 | 01:29 PM
Where I race at there is no roar rules , just track rules. I could race a 5 port .
What about the 3 port ....will it work on the losi and is there a whole lot of difference in the power ?
Old 07-24-2005 | 03:30 PM
well I guess Ill have to go with the 3 port...... : (
Old 07-24-2005 | 06:07 PM
chelopr's Avatar
ORIGINAL: ronnie582
3 port engine usually have more torque than 5 port and 5 port have more RPM. That why 3 port is better for your losi. go 3 port it's better for your stadium truck.
Old 11-21-2005 | 08:45 AM
i think you must change cranckshaft with a short crankschaft as TZ(S)
