RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
Losi XXX-t low compression
Old 07-26-2005 | 03:27 PM
cp_phx's Avatar
Default Losi XXX-t low compression
I know someone with a Team Losi XXX-T with a OS engine that has low compression. I might be able to pick this up cheap. It's complete with accesories. The only thing it needs is a start box or I can convert it to pull start if I change the pipe.
So I was wondering if anyone knows how difficult a sleeve kit is to install? Let me know.
Thanks.
Old 07-26-2005 | 04:13 PM
Default RE: Losi XXX-t low compression
The sleev is easy to replace just remember u have to break it in again.
if you not sure get the manual with it
Old 07-26-2005 | 06:20 PM
its easy take the head off, take the back plate off take the con rod off the crankshaft pull the piston and sleeve and con rod out take the con rod, put the conrod on the new piston and sleeve, place in block, attach the con rod to the crank and put the back plate and head on, rebuild! wow
Old 07-26-2005 | 06:33 PM
cp_phx's Avatar
Easier than spending the extra money for a new engine???
Old 07-27-2005 | 08:12 AM
yeah it is
you can get a rebuild kit for close to $40
it isnt that had to rebuild a engine
Old 07-27-2005 | 08:13 AM
ohhhh yeah post 1000 lol[sm=bananahead.gif]
Old 07-27-2005 | 12:18 PM
cp_phx's Avatar
The OS engine is a CV Series .15 Engines...still pretty easy??? The sleeve kit is $50, is that about average and is there anything else I'll need?
Old 07-27-2005 | 12:24 PM
theres nothing hard about changing it, i reguraly take ou the sleeve and piston in my trx .15 for fun
Old 07-27-2005 | 12:47 PM
all that you need is a piston,sleeve,conrod,wristpin clips,and gaskets
Old 07-27-2005 | 12:48 PM
cp_phx's Avatar
Then for fun do you want to do mine? ha ha. Anyplace your recommend for the sleeve kit?
ORIGINAL: cossie
Old 07-27-2005 | 01:01 PM
here is the piston ans sleeve
http://www2.towerhobbies.com/cgi-bin...&I=LXCJ12&P=PU
head gasket
http://www2.towerhobbies.com/cgi-bin...&I=LXCN14&P=PU
dont know about a con rod
Old 07-27-2005 | 01:07 PM
cp_phx's Avatar
thanks man.
ORIGINAL: losi xxx-ntkid
head gasket
Old 07-27-2005 | 01:14 PM
you dont need to replace the con rod and just to let you know it will revamp the engine but wont be as good as new but it will be good, and if you just save up a little more money you can get a good brand new engine for a litle more!, i was going to rebuild my os 12 cvr but i bought a dynamite .12spd for like 80 bucks just shop around
Old 07-27-2005 | 01:17 PM
os .12 cv here for 80 and for 20 buck smore you can get a pull start
http://www2.towerhobbies.com/cgi-bin...?&I=LXBZ14&P=7
Old 07-27-2005 | 01:22 PM
cp_phx's Avatar
Good looking out. I can't get a pull start because my pipe or that would be an idea.
If anyone is interested...I have an Traxxas Rustler that I will trade for an OS engine for a Losi ST.
ORIGINAL: motoman931172
Old 07-27-2005 | 01:42 PM
a s 25 engine out of my savage ? jk its gonna be gon in a few days
Old 07-27-2005 | 01:50 PM
cp_phx's Avatar
Old 07-27-2005 | 01:56 PM
that is so wrong
you ask any one that builds engines on rcu
and they will tell you that yes you do need to replace th connecting rod
the connecting rod streches over time and becomes weak so if you dont replace it now it will cause you problems later
Old 07-28-2005 | 12:18 AM
econ909's Avatar
its good to replace everything even the carb o-rings, glow plug, air filters. i fergot after how many rebuilds you need to replace the crank because its wears down and causes play/vibration and will distroy your conrod. it will be cheaper and will teach you a few things. like how to apreciate your rc car
