more problems with the jato
ok i have More jato problems.... i got a pull starter put in and i charged my glow starter 18 hours and put a new glow plug in and primed it for 1 second at a time, it just wont come close to starting... also has new 20% top fuel in the tank
FL
haha i laugh at you guys that ran out and bought the jato with out waiting a while for traxxas to work out all the bugs, sorry i had to say it
try leaning it out a little
My Feedback: (12)
IL
ORIGINAL: JoeBurgarino
are you seeing the fuel go to the engine while priming? do you by chance have a pin hole in your fuel line that is letting it suck air?
are both lights coming on with the starter?
ORIGINAL: losi xxx-ntkid
are you sure you charged it correctly, was it warm? lean out your idle a bit and change the glow plug.
that's because a lot of starters buy traxxas products, and the 2.5 isn't the easiest engine to tune if you don't know what your doing. Starters forget to read the manual i guess.. haha
CA
your first problem is you bought a jato second is the motor is by far the hardest motors to tune and third prob is you bought a jato
My Feedback: (12)
IL
ORIGINAL: GTdirtracer
UT
ORIGINAL: thestratcat
I really do wonder on this one.. my t-maxx is always off, no matter how much I tune.. the OS in my ST is always within a hair of being right.. I'm thinking that the next upgrade to my t-maxx is going to be an OS engine!!
The 2.5R's and 2.5's basically same engines are cake to tune. If you can tune a OS or other engine you sure shouldn't have a problem with a 2.5R. Most peoples problems are fuel....2.5's are fussy with the fuel they use
GTdirtracer Date 7/29/2005 7:10:28 PM
nothing is wrong with it, i prime it for 1-2 seconds, at hobby town they have no idea whats wrong, the jato is the coolest nitro out there, it isnt hard to tune, and u idiots saying i should read the manual ive read it cover to cover 3 times its long but has lots of ironious stupid info like 3 pages on how too install the antenna tube
My Feedback: (12)
IL
ORIGINAL: badz
Ha probably, if their so hard to tune, then why can I tune it? If it's so hard to tune, why was it easy, and why is it a good beginner engine? If their so hard to tune, why do I not need to keep messing with it everytime I take it out? I only need to tune it on a normal basis, just like almost every other engine out there? (And this whole thing is about my expirences, if yours are exactly the opposite, then you suck
CA
2.5s suck thats final and how hot do you run your motor, or do u not even know---noob i cept my 2.5 at 225 all day on an 80 degree day like to c u do that
Jeeeeeeezzzzzzz, what is this hobby coming to? Idiots and nitro dont mix.
OH
UT
Last week was 100+ days here my Jato runs at 180-195 on those days and thats running on asphault...alot of long wide open running. Staying at 225 on a 80 degree day is something even an poorly tuned engine can do. Don't brag cause your obviously clueless. Maybe you should buy a Jato with that other dude and both of ya's can search for the primer bulb
As far as a 2.5 being hard to tune it isn't...it's a piece of cake to tune. The problem of tuning comes from one of 3 things and it's for all engines.
#1 Poor quality of fuel
#2 Glow Plug fried
#3 Person tuning engine is clueless how to properly tune a engine.
I'd think anyone with some real Nitro experience would agree with those 3 things as being most common problems of poorly running engines.
