RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
Cooling head recommendations
Old 07-31-2005 | 07:01 PM
meatloaf's Avatar
Default Cooling head recommendations
Can a anybody recommend a good cooling head for the 2.5 Rustler? Thanks
Old 07-31-2005 | 07:16 PM
ThunderbirdJunkie's Avatar
Default RE: Cooling head recommendations
yeah, the stocker...
or buy a $100 one that comes with a free engine below it
Old 07-31-2005 | 10:20 PM
NITRO 888's Avatar
ORIGINAL: meatloaf
Ya dude,
You might want to have a look at the golden horizon line . i run with one and like it very muc http://www2.towerhobbies.com/cgi-bin...&I=LXEMN8&P=0h
Old 07-31-2005 | 10:39 PM
meatloaf's Avatar
Thanks for a REAL answer. The first reply must have been from a 2 year old.
Old 07-31-2005 | 11:10 PM
ORIGINAL: meatloaf
Wahhhh, don't turn a jovial post into flamebait, crybaby.
PS: Welcome.
Old 08-01-2005 | 12:10 AM
meatloaf:
my point was, that unless you just want the bling factor, a cooling head isn't gonna do much on any engine unless it's been substantially reworked.
just for the record, i'm 12x the age you assumed 2 year olds dont have my dry quick wit
Old 08-01-2005 | 12:16 AM
I'm cross-drilling my head and adding liquid cooling and a no-crap radiator from my 300ZX. Then I'll take the turbo and intercooler and turbo from my SRT and plop it on as well.
Old 08-01-2005 | 01:08 AM
that's a Traxxas SRT right
(yes, i know what an SRT is, dont bother)
I like my cross-drilled brake lines, personally.
Old 08-01-2005 | 01:33 AM
badz's Avatar
ORIGINAL: khlept0
And what forget the NOS? How dare you
Old 08-01-2005 | 01:42 AM
ORIGINAL: ThunderbirdJunkie
I'm sure they're not your brake lines that are now cross-drilled. Perhaps the dickhead who cut you off earlier.
Old 08-01-2005 | 03:14 AM
www.kalecoauto.com
seriously, i know what i'm talking about, click the link and you'll get it.
GEEZ man, this guy complains about somebody taking my jestful post out of context, and then does the same himself.
Old 08-01-2005 | 04:21 AM
I'm wondering why they don't have any frequency grease in stock, I've been trying to get my tranmitter working forever.
Old 08-01-2005 | 06:25 AM
I LIKE THE NOVA RACE PRO...NOVARC.COM I THINK.
THEY WORK AWESOME AND ARE VERY EASY TO CLEAN.
I HAVE THEM ON 2 2.5S AND ON MY HYPER 7 .21.
Old 08-01-2005 | 09:56 AM
monsterpede360's Avatar
hey man my brother needs a new cooling head. This is the right thread for his problem.
Old 08-01-2005 | 02:29 PM
ORIGINAL: monsterpede360
what kinda engine
if its not a 2.5 then no its not the right thread
Old 08-01-2005 | 04:02 PM
tommythecat's Avatar
I have to second on the golden horizons head, but then again I wouldn't change it unless you have ruined your stock head. I cross threaded my plug on my stock head and all the LHS had was the GH head, I've been very happy with it, plus it has a removable button so the next time I cross thread a plug all I need is a new button instead of a whole new head
Old 08-02-2005 | 01:10 AM
Skullbasher's Avatar
I have to second the stock head. For the exact same reason.
An aftermarket head can accually kill your engine. If the head cools too much, the piston sleeve will not expand to proper size and will cause premature wear on the engine. I would rather run my engine at 270f than 180f (assuming it is still lubricated).
I got a hardcore racing head a long time ago, and now I have a peice of $40 aluminum that I only use for pictures.
Old 08-02-2005 | 09:27 AM
ORIGINAL: Skullbasher
The is why I reccomend the GH head, it is very slightly better, meaning that it doesn't overcool. 7 gallons through my still strong trx 2.5 is proof enough to me. I found it seemed to lower my temps about 20 degrees on average. However, I am talking about in warmer weather. I did pick up a new stock head to use during the winter, and I actually wrap it in foil and a sock. But for running in normal 50-100 degree weather the GH head is awesome.
Old 08-02-2005 | 08:39 PM
ORIGINAL: tommythecat
Yes, but you shouldn't need to run 20d cooler. If you are overheating, then getting a new cooling head is not the solution. Although if you are running in very hot weather(like hundreds). And that is causing you to run a little hot, then I agree, a new cooling head might be benificial.
Old 08-02-2005 | 09:53 PM
I agree, but with a proper tune my trx 2.5 seems to peak at around 290 when running in grass, and usually runs 240ish under normal dirt and pavement driving, so a 20 degree drop doesn't drop you into the sub 200 (too cool for proper expansion) range. Although, that being said there is really nothing wrong with peaking at 290 as long as the high temps are due to climate and running conditions and not lack of internal lubrication. I think we are basically on the same page. Your just emphasizing the point that using a bigger head to cool an engine that is running hot due to a lean condition will only mask the problem and allow the p/s to clearance prematurely regardless of in-range temps. I guess the point is that you shouldn't use a larger head to try to fix an overheating problem, as doing so will only hide the problem and not actually correct it. If you buy an aftermarket head it is important to do so knowing that fact or else you will wonder why your engine is shot after 1 gallon even though you never saw it overheat. Personally the only reason I bought the head was because I stripped my stocker and the GH was the smallest aftermarket head they had at my LHS. The only reason I leave it on is because it looks a bit nicer and seems to stand up better to having the truck skid on it when I flip over occasionally compared to the stock head which tends to snap and chip when you mess up and end up riding on it. Like I said, I do still have an extra stock head that always goes on when I'm running in cold conditions. Running cold is just as bad if not worse than running hot because of running lean.
Old 08-02-2005 | 11:02 PM
Here is a spiffy one: http://www2.towerhobbies.com/cgi-bin...&I=LXETE3&P=0h
*Warranty void if tool breaks for any reason whatsoever.
