Tire question
VA
My grandson has been running his Evader BT (BX converted to the ST suspension and gearing but still using the buggy body) in our backyard a lot lately, but he is killing the grass with all that 30% exhaust. He can run the truck on the street in front of the house, but dirt tires don't last long on the pavement. I figured just put a set of street tires on the back for the pavement and switch the dirt tires back on when he is running it in the dirt, but it doen't seem to be that simple. The dirt back tires have a 4 inch diameter, but all the pavement tires I've found have a 3 7/16 diameter, or less. Does anyone make a set of pavement tires the same size as the dirt tires uses on a Duratrax Evader ST?
well humm doe he have the evader st rims u are going to need new rims
here the bx and st are brothers and can use the same rims so check this out
get these tires if your lookinf for JUST street
http://www2.towerhobbies.com/cgi-bin...&I=LXLN12&P=ML
any 2.2 will work!!
or if u want simple link here
http://www2.towerhobbies.com/cgi-bin...?&I=LXDW24&P=7
green
http://www2.towerhobbies.com/cgi-bin...?&I=LXDW25&P=7
and if u want a all round tire so u can go on street and dirt and grass and not have to take the tires off here (i tink these work better for street and thew wont were out)
http://www2.towerhobbies.com/cgi-bin...?&I=LXUM92&P=7
http://www2.towerhobbies.com/cgi-bin...?&I=LXDU11&P=7
and if u want a tire that will LAST long time and will work with grass if u so want to get these
http://www2.towerhobbies.com/cgi-bin...?&I=LXUM93&P=7
and i dont know what setup u have u can get new fronts if u want but i dont know to to mutch about the bx u might need new stuff but the rears will work
i hope this gives u a idea and tower is a good place to get cheaper stuff from u can get tires and rims for the price of tires at your LHS
any 2.2 will work!!
green
