check this out!!!!!!!!
ok cool now i have your attention im after a little lesson in nitro cars. me and a few of my friends have nitro stadium trucks. the models differ but mines a hpi rush evo. we all have the same basic problem. it will start up and idle pretty fine but as soon as you try to go it stalls. is it too much air? too much fuel? too little of either of them? how od i adjust it etc etc? high speed needle up or down?
lots of questions
just want to sort it rally but also know why it does it and why adjusting sed needle makes it work
cheers guys
lots of questions
cheers guys
IL
ORIGINAL: brownstone101
when your truck idles it cant burn all the fuel so it dies give it little blurps of throttle and it will go when u punch it
ok i never knew that thanks i will do that!!! maby retune my motor IF I GET MY TOWER SHIPMENT TOMORO DANG CLUTCH SPRING GRRRRRRR[:@][:@][sm=punching.gif]
ORIGINAL: lethalfrog
RTFM, it is explained in the second part of the engine section of the manual.
on a slightly different matter, but related, when i go onto other forums like rctech.net, it blows me away cos im so used to this forum. the ppl there talk purely about rc cars, and dont post smart ar$€ replies which are attempting to bash the person who asked a simple question.
AZ
ORIGINAL: samisnake
what if he bought the car on ebay and never got a manual. i never had a manual, so should i have RTFM?
cool. i didnt get a manual with it. was my cousins. so how do i lean it off. i know i adjust the high speed and low speed needle. but which way. counterclockwise or clockwise to lean it off. how bout that tiny little screw on the carb. should that be all way tight or loose?
the little screw is the idle screw. u adjust it so it does not allow the carb to fully closewhen the brakes are applied. you want about a 1 mm gap when the brakes are applied to allow it to idle.
you might want to go on this link to get the manual
[link=http://hpiracing.com/instructions/instruct-rushevo.htm]manual[/link]
