Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Nitro Stadium Trucks
 Official Stadium Truck Engine Tuning Thread >
RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
Old 08-06-2005 | 05:19 PM
MRTC3's Avatar
Default Official Stadium Truck Engine Tuning Thread
Myself and brownstone 101 wanted to make a thread about engine tuning about nitro stadium trucks. Anything to do with nitro stadium truck enginges should go here.I will start the diccussion off by asking a question about hot weather running. Brownstone101 and I want to know if the heat will affect the way your car runs feels,acts and sounds?
Thanks guys - MRTC3 and Brownstone 101
Old 08-06-2005 | 05:21 PM
brownstone101's Avatar
Default RE: Official Stadium Truck Engine Tuning Thread
ya it just dosnt sound right to me i tuned the lsn and i got bottom end poer but when i go WOT it sounds like a high pitch weeeeeeeeeeeeeeeeeeeeeeee sound or i dont member what WOT sounds like
Old 08-06-2005 | 05:26 PM
thestratcat's Avatar
My Feedback: (12)
I tune by ear/temp gage.. my truck hasn't changed much since spring and it's been hot and humid here..
Old 08-06-2005 | 05:29 PM
well i dont have a temp guage and i dont member what WOT sounds like [X(]
Old 08-06-2005 | 05:33 PM
My Feedback: (12)
ORIGINAL: brownstone101
I kind of relate it to a high E, but that won't help you either
I'm a firm believer in a temp guage, they are only 26 bucks, mine is hanging on the handle of my radio so I'm never without it (when I have the cars out anyway)
Old 08-06-2005 | 05:39 PM
My Feedback: (12)
this came with my t-maxx and I've got it taped in my box..
HIGH SPEED NEEDLE
higher humidity - set slightly leaner
higher barometric pressure - set richer
higher temperature - set leaner
higher altitude - set leaner
higher notro % - set richer
Old 08-06-2005 | 05:42 PM
ok well it dosnt seam as fast and reves faster i just took som pics of my clutch i just got new spring on BUT i think the pads are gone
what do u think []
take a close look and tell me if its a yay or nay on new clutch pads but then i dont know were to get some
so if there taost what clutch pads work?
rc10gt work
xxxnt
is there a aftermarket clutch out there thats teflon or somethin
IDK im so confused[&:]
i did grind the well out for the spring cause it was stick up realy high
ID:	306476   Click image for larger version
ID:	306477   Click image for larger version
ID:	306478   Click image for larger version
Old 08-06-2005 | 05:58 PM
o ya it dose have brand new clutch spring on it if thats a factor maby?
and sometimes u get that gut feeling that something is not right well i ran it and i got that feeling[:'(][:@][]
Old 08-06-2005 | 06:06 PM
the sound will be different if you have a tuned pipe on it. each pipe makes its own unique pitch for every rpm range. i do almost 3 full turns on HSN and about 1/8 turn out on LSN makes a perfect mixture for this weather on my engine. I have a rush evo which has a T-15 engine, really easy tuning. getting good at tuning can take a while it took my like a month to get it down and once you have your engine for a while you can tell where you want to buy the sounds and the temperature of the engine. later
Old 08-06-2005 | 06:12 PM
MRTC3's Avatar
i got a new spring could it be slipping cause it a new spring
Old 08-06-2005 | 09:43 PM
its the clutch spring its new so its not enguaging as well i will get new ones soon but i think its fine and it will get better the more its used but now im woried about tuning [:@]
