4 tec help
Old 03-13-2007 | 02:52 PM
Default 4 tec help
Today my 4 tec stasrted i guess taking itself out of gear and free reving occasionalyand then it will click and put itself back into gear. Does anyone know what this might be?
Old 03-13-2007 | 09:43 PM
ASSOCIATED_DRIVER's Avatar
Default RE: 4 tec help
Check your gear mesh and clutch shoes.
Old 03-13-2007 | 10:50 PM
Ya i just purchased a new aluminum clutch and lightweight flywheel for when i drop in my new trx 3.3. the gears line up ok but i think there might be a problem with the part of the 2 speed that tightens onto the output shaft where you adjust the shift points. But with the clutch shoes it will click after the engine revs and then it will take off just fine.
