Questions
Old 03-19-2007 | 07:16 PM
Default Questions
is it bad to clean you exhaust out with water
Old 03-19-2007 | 08:56 PM
hpi apollo's Avatar
Default RE: Questions
as long as its not attached to the engine water in te engine can cause lotsa problems, water works just fine, i used alcohol though
Old 03-19-2007 | 09:52 PM
HeLLsGoD's Avatar
Use metholated spirits, degreaser or automotive cleaners. These work well because they get rid off grease, oil and other scum. Water will make it rust if its a metal pipe plus water on its own sucks at cleaning
Are you talking about cleaning the inside of your pipe? because i dont think anyone does this
Old 03-20-2007 | 05:06 AM
ya i did but i diconected it's plastic tho
