no-idling on my buggy...
Old 03-22-2007 | 08:59 PM
Codeblack's Avatar
Default no-idling on my buggy...
Ok, pardon my newbie question but what do i do when my idling is not working... I tried to tune my engine (starting and not finishing with the HSN) and slowly my idling stopped working, so basically my brakes turn off the engine [&:][:@][&:][:@]. What should I do? Is the clutch bell too tight, too loose, or did I do something wrong with the HSN???
Old 03-23-2007 | 12:09 AM
SaucerHead's Avatar
Default RE: no-idling on my buggy...
I had the same problem on an old O.S engine of mine where when i applied the brakes it would cut off the engine because the carb linkage would not stop goin back (rotary carb). I kept having to adjust the idle needle. It seemed if i tightened it all the way down then the carb would not go past that resting point. i.e when the brakes are applied. But that was my case. not sure if yours is the same.
Old 03-23-2007 | 12:31 AM
Codeblack's Avatar
I believe we you had the same problem. Could you tell me how you fixed it?
Old 03-23-2007 | 02:11 AM
SaucerHead's Avatar
Well as a temporary fix, i would move the throttle linkage on the carb all the way back till the carb is completely shut. Then i would turn the idle screw clockwise until there was a .5-1.0mm opening in carb window. That should stop the linkage from going too far back. But im my case, my low speed needle went bad on my carb and now its inadjustable. So long story short, i need a new carb for that engine but i've gotten great use out of it and plan on getting a new one anyway. But try that. you may need to loosen your low speed assembly and retighten it but just use caution as all the parts can go out of wack if messed with inproperly. See if that works. good luck with it.
Old 03-23-2007 | 06:27 AM
Codeblack's Avatar
hahaha, omg, that sucks... Thanks for your help, ill do my best
Old 03-23-2007 | 07:25 AM
Codeblack's Avatar
actually one more little question. Do i do this tuning you speak of while the engine is running or thats not necessary?
Old 03-23-2007 | 08:50 AM
RCtruckRacer's Avatar
Return both needles and idle stop to stock settings and try this:
Why do we ‘tune’ our engines? How is it done? This guide assumes that you are familiar with all of the parts of your R/C's engine. If you are unsure what a Low Speed Needle (LSN), High Speed Needle (HSN), idle screw etc are, please refer to the manual (RTFM).
Tuning a nitro/methane 2 stroke engine literally means adjusting the air/fuel mixture inside the chamber. This is done by means of adjusting the amount of fuel that is allowed to flow into the carburetor via needles which can be opened and closed. Most of us know that there are a wide variety of factors that affect that air/fuel mixture in the chamber other than just adjusting the needles. Because of this an engine may have to be tuned several times in the same day for optimum performance. Not maintaining an optimum air/fuel ratio can result in poor performance, or even engine failure!
There is a point, in every engine, at which air/fuel mixture will allow the engine to obtain its maximum HP and RPM’s. Tuning your engine to that point can be dangerous, as the mixture is somewhat lacking in the lubricants necessary to give maximum protection to the engine. Therefore, most people will want to run slightly rich (more fuel in the mixture) of that point. This is referred to as the ‘Sweet Spot.’ Some racers will run at pure max potential, but they also don’t usually care if the engine only lasts a gallon… Running at those settings can be very dangerous because being too lean is just a very slight adjustment away.
And running lean is the real engine killer, not temperature. With proper lubrication, the internal components of an R/C engine can easily withstand temperatures of 300F, maybe even more. The thing is, these engines are designed to operate at temperatures around 210 – 270 F. While there is the possibility you will encounter an engine and conditions that dictate the temperature at proper tune is over 300, it will be a rare occurrence. What that boils down to is that there is a good possibility that there is a problem if your engine reaches too high of a temperature. That is why it’s a good idea to monitor the engine temperature, but not use it as a guide for adjusting the air/fuel mixture in the engine.
So, how do you get to that ‘Sweet Spot?’
1) Start out with rich settings. If you are unsure how to go about this, an easy way is to start with stock needle settings. This includes the idle screw - make sure it is set at factory settings, usually a 1 or 2 mm opening for the idle stop. The factories always set engines rich for break ins.
2) next, warm up the engine. Try not to hammer the throttle too much while its still bone cold, but slowly work your way up to a couple WOT runs.
3) Now that the engine is warmed up (1/2 tank is good), do a couple WOT runs of about 50-100ft in front of you and pay attention to the pitch of your engine. The higher the pitch, the more RPM's its doing.
4) Now lean out the HSN by 1 hour increments (30 degrees, 1/12 of a full circle etc) and continue to do some WOT runs in front of you. The engine's max RPM's should continue to go up each and every time you lean out the HSN by those 1 hour changes. If it doesn't, you have reached the top end and need to richen by an hour. Make sure that you do not continue to lean out the HSN after max RPM's have been reached. You will damage the engine.
Congratulations, you just found the sweet spot. Now, if you notice that the car/truck bogs a bit at take off, lean out the LSN (again 1 hr increments) until it will take off at the touch of the trigger. Keep in mind that any needle changes won’t take effect immediately – do a couple of long runs (50 feet or so) to make sure the air/fuel mixture has corrected to the current needle settings.
And you're done. At this point I like to temp the engine to get a baseline reading for the day.
This is a simple and fool proof method of tuning that everyone can do. Regardless of your experience.
Old 03-23-2007 | 01:33 PM
Codeblack's Avatar
That’s some lovely info there RCtruckRacer, thank you. Could you tell me how that will fix my non-idling problem? I am really confused because from that info it seems like my idling is supposed to function before i do what you said, but I can barely put the car on the ground when the wheels are already at 70RPM. Dont I have to fix the idling problem first? I am just curious but for now ill go out this morning and try out what you said and see if running my car around will help get the idling back...
p.s. my car has been put back to factory settings a couple of short runs ago
Old 03-23-2007 | 03:10 PM
Codeblack's Avatar
Never Mind, my clutch bell is broken bigtime... i f** knew it
Old 03-23-2007 | 06:49 PM
I was responding to this:
But I am more than happy to put you on ignore. Good luck.
Old 03-23-2007 | 10:06 PM
Codeblack's Avatar
I am sorry man, i didnt mean to sound rude or anything believe me, its a minor misunderstanding since i referred to the problem of putting the car on the ground when it was already at high rpm. Anyway hope you didnt take it personally. Lol, apparently my clutch bell shoes melted and totally ceased the clutch, so no idling. I bought new aluminum shoes and it sshould run no-problemo. had no idea that it was the clutch bell problem and didnt think of taking the engine apart to figure it out (being one scared newbie). so anyhow, sorry again and take care.
