Tires for bashing?
Old 03-27-2007 | 03:07 PM
cnguyen831's Avatar
Default Tires for bashing?
I have a Evo w/ OS CVRX installed. Ditching the stock tires that came with the car. What tires do you recommend for bashing? Parking lot surfaces.
Old 03-27-2007 | 03:13 PM
hpi apollo's Avatar
Default RE: Tires for bashing?
for a clean surface, i think some 45 shore foams would last the longest
Old 03-27-2007 | 03:23 PM
iexion's Avatar
Either those or stick with the stock. If your bashing then i would say stick to stock. PLUS tires can get costly after a while. Hpi makes better quality R/C products then what people give them credit for, not saying there the best by any means. But the stock tires would get the job done if your just "parking lot" bashing
Old 03-27-2007 | 03:24 PM
no i disagree with hpi apollo. i had my hpi rs4 3 and had it for three years and only got 2 pears of tires. get some hpi v-groove pro compound. part # 4540
Old 03-27-2007 | 03:25 PM
do u still have the stock tires and motor
Old 03-27-2007 | 03:28 PM
cnguyen831's Avatar
Still have stock tires. Sold my T-15. I should have gotten an 18ss from the start. Because I bought everything to make it an 18ss
Old 03-27-2007 | 03:47 PM
hpi apollo's Avatar
nitro man, i could run through those crap hpi tires in a day (easily) the hpi 45 shore tires wer the only ones that actualyl held up quite well and gave me good grip too
Old 03-27-2007 | 05:28 PM
how long had u have the evo
if u got it a month ago u could trade it in for the evo plus and it is the same power as the 18ss
Old 03-27-2007 | 06:26 PM
those stock tires are junk!! the tread wore off in no time! I went with these
http://www2.towerhobbies.com/cgi-bin/WTI0001P?&I=LXM991
these have held up great
Old 03-27-2007 | 06:45 PM
for me, with the stock t-15, the tires are dead with 10 tanks...maybe. i have huge camber or toe issues that need to be addressed also.
Old 03-27-2007 | 07:18 PM
iexion's Avatar
If you have the right running area i.e. skate park smooth parking lot, then go for the foams. Any one can burn thru tires if the keep there index finger hammered down, the point is trying to find tires for general purpose area (like all seaon tires for automobile). I've gone thru close to 2 gallons before i needed new tires
Otherwise
The best advice is to get an idea of the surface your going to be running on and then pick the correct tires. V-groove sure, but there are different compounds that you can find. You can also Look up the compounds on Hpi's website to get a better idea
Help this helps (without everyone starting to BI**H in this trend)
Old 03-27-2007 | 07:56 PM
cnguyen831's Avatar
Thanks. My evo is 3 years old. Last mod was a OS CVRX. Switched to drift tires. And want an alternative when I don't want to drift.
Old 03-28-2007 | 06:50 AM
HeLLsGoD's Avatar
Best drift tyres are the stock x-thread tyres. Give it a tank and it will be driftin' sideways haha
Here this might help, Have a look at the IMEX wheels. Have a look near the bottom where iexion bought one. Cant believe his selling his sweet setup []
[link]http://www.rcuniverse.com/forum/m_5350565/mpage_1/key_/tm.htm[/link]
