Transmission
I was out bashing today and then when i switched to reverse it wont move
so i switched back and it wouldnt go forward
when I turn the Spur gear to the left it is stuck but when turning to the right it spins freely
when the truck is on the ground I cant push it forward seems like its on full brake but its not
when I switch back to reverse, I can push the truck forward and back
I have a Savage 25
and its 2 speed
everything was perfect, tuning and was poppin wheelies
but like 10 mins later this happened
I have a Savage 25
and its 2 speed
Check the clutch choes. That sounds like the problem my friend was having. They probably got shaved down so much that the back edge came up between the clutch bell and the flywheel and got stuck.
Thanks A1Viper for replying quickly
I checked the clutch shoes and clutch bell
it spins freely, nothing is stuck
but I took out the tranny and turned the Spur gear to the left and it is stuck but turns right freely
So I got the tranny out now
the gears inside look perfect, nothing stripped or worn
I looked at the reverse module and the gear of that is stuck it wont turn any direction
I can turn the Spur gear freely
its the stupid Reverse Module
looks like Ill have to open that up and see
