The reciever does not fit in reciever box!!
Hi,i tried putting the TF-1 reciever in the reciever box(inside the area of the radio box) on the x ss.It does not fit lol.Even if i grind some of the plastic away it still won''t fit(hard to explain)So im asking you guys where i can put the reciever?
It should fit. If you look on the underside of the rx you'll see a hook like shape. This get hook in the middle between your servos before you slip it over the security nut.
So on the rf-1 reciever where is the underside?Is the hook 2 lumps?And what is the security nut?Sorry but i hardly understand anything lol.
