HPI Monster Truck Forum Talk about HPI monster trucks here. The infamous Savage 21, SS, .25 or any other HPI MT. You can optionally discuss HPI in our general MT discussion forum if you prefer.
Best suspension?
Old 05-07-2007 | 07:12 AM
Default Best suspension?
Hi guys! I'm Joao and live in Lisbon.
Bought a Savage X recently (never had any nitro RC before) and I am trying to find out which is the best suspension (essentially shocks) to fit in it.
Whent I bought it, I also got the HPI aluminiun shocks and filled them up with 600 oil in front and 800 oil for the back (recomendation from the guy in the store). The 800 oil for the back is definitely too much dense as the rebound is slow. So I am thinking of putting the same oil in the front and back (600). I also got the set of progressive springs. So any help on setting up will be much appreciated.
There are many pictures of savages with a single shock per wheel. What it is how does it perform?
Thank you for your help.
Best
J
Old 05-07-2007 | 09:54 AM
-SomeGuy-'s Avatar
Default RE: Best suspension?
Welcome to the forum!
The shocks you have now are very good and the only way of getting better shock action is to do the LST shock mod. For this you need a special kit and 4 lst shocks and your set. As for the oil your using its way to thick, i run 25wt in all my shocks and its just fine for me. 600 to 800 is much to thick, get something between 25 and 40 to replace it or you will bend the shock shafts when landing a big jump or hitting a bump.
Old 05-07-2007 | 02:39 PM
46u's Avatar
46u
Been running the stock shock on mine for 8 plus gallons. I race mine and run 25 weight oil all around with one red and one green spring each corner. On the track I only get about 5 or 7 feet of air.
Old 05-08-2007 | 04:32 AM
Thanks!
Do you think 25 would be 400 or 500?
Old 05-08-2007 | 04:35 AM
itsnotskidding's Avatar
^^^^ sounds a good set-up!!..
i run the green rear now and red front, 30wt front and rear... and its set up lovely for racing!, i run the allu shocks aswell dude, i will say look out of the case's seem, they crack under alot of pressure and leak a little, mine did on my savage,
if i could go back id get a lst converstion, but my truck ows me far to much $$$$$$...
