HPI Monster Truck Forum Talk about HPI monster trucks here. The infamous Savage 21, SS, .25 or any other HPI MT. You can optionally discuss HPI in our general MT discussion forum if you prefer.
One last question!
Old 05-11-2007 | 09:52 PM
Default One last question!
Hi before i start my savage x ss that i bought off ebay(pre used 6 tanks) as i was putting the flywheel to bdc i noticed that it tthe flywheel turned both ways,is this normal?
Also i was going to buy nova allot shoes but i realised i will need something like mugen 1.0mm springs.So im going to buy mugen shoes and springs together from ebay.
Howlong will the springs last?
Howlong will the shoes last? Thanks.
Old 05-11-2007 | 10:26 PM
evaderstbasher's Avatar
Default RE: One last question!
as for the flywheel, yes i beleive it does go both ways... and as for the shoes and springs.. i just put some new ones in my savage, mugen alum. shoes and mugen 1mm springs...
amazing difference
Old 05-12-2007 | 12:50 AM
Ok,its started thundering and soon rain here now.GRRRRRR [:@] [:@] Antone know hwolong the mugen shoes last?And howlong the springs lasst?
Old 05-12-2007 | 01:35 AM
i would think pretty long.. AT LEAST a gallon i would almost guarantee...
Old 05-12-2007 | 03:18 AM
Are you talking about the alloy ones?But how about allot mugen clutch shoes howlong would they last?
Also howlong do the springs last? Thanks.
Old 05-12-2007 | 03:31 AM
didnt i just answer this?
the only reason to use mugens in your savage is to have hte alum...
so yes, i was talking about the alum. shoes.. they should last your quite a while.. and the shoes/springs together arnt exspensive..
Old 05-12-2007 | 03:42 AM
Ok howlong will the springs last?
And also i thought plastic shoes last a gallon how long do plastic shoes last then? Thanks.
Old 05-12-2007 | 06:44 AM
Your springs will outlast your shoes. I've been running the mugen alloy shoes for a while now & they definitely bite better than the original shoes. I've found the mugen alloy's also wear quicker than some of the other alloy shoes on the market also so you have to decise if you prefer better cluch engagement or longer lasting alloy shoes. I would also recommend the 1.0mm springs over the std or the 1.1mm as they seem to have the better take of point for clutch/engine rpm engagement
Old 05-12-2007 | 08:52 PM
So howlong will the platic hpi shoes last(want to know so i know how long i have to i will need to change them)
Old 05-12-2007 | 09:48 PM
benzzyo5's Avatar
i also run the mugen alluminum shoes with 1mm springs
they last around 4 gallons. and i just replace the springs when i replace the shoes. but you don't have to, i just do it as a precationary so the springs doesn't break and ruin my day
Old 05-12-2007 | 10:15 PM
The std shoes will last around the same time as the alloy...maybe a little less, maybe a little more...all depending how you drive. The plastic shoes will slip more than the alloy so heating up your clutch bell more & affecting the bearings at the same time. Plus if you run a plastic spur gear the heated clutch bell will also soften the teeth on the spur during hard bashing& can cause the spur to melt/strip.
Go with the alloy shoes, you won't be dissapointed but they do require a little maintenance be de-burring the edges of the shoes from time to time
Old 05-14-2007 | 01:23 AM
Ok so platic shoes last around a gallon,mugen last 4 gallons,howlong do novas normally last?
Old 05-14-2007 | 07:50 AM
Foxy's Avatar
They last until they need replacing, depending on your driving and tuning skills. End of story.
Us telling you how long they last won't change how long they ACTUALLY last. The mugen shoes are as good as any other. Get them on the car already!
Old 05-15-2007 | 01:25 AM
So even though novas are more expensive they last just as long as the mugens...
Old 05-15-2007 | 06:50 AM
So...,how long do alloy ones last?
