savage is not starting
okay so im starting my savage 25 and nothing not even a pop i pumped the lines andthere was gas geting to the and later on i herd a clicking noise kind of i dont know if it was it trying to start but there was a lot of gas splattering out of the carb.
help please thanks,
help please thanks,
Thats kind of vague. It could be alot of things. If you have a rotostart it could be the one way bearing. It could be a bad seal in your carb. It could be a broken con rod or lose of compression. Or it could just be flooded or have a bad glow plug.
If you have no compression your engine is shot and needs a new piston and sleeve. Or a new engine.
Take the engine out and take the back plate off to see if there s any damage inside or any loose bits. Next take the cooling head off and chec for damage to the top of the piston or scoring along the sleeve. Post pictures if you can.
one way goes one way and the sleve is absoulutly clean
this is my first tank of different fuel though i went from odonnall 20% to dynamite blue thunder race formula 20% could that be the problem
