engine washer?
CA
Hi guys
my engine washer just next to the front clutch bell bearing is bent, allowing the CB to move forward and backwards almost freely, and resulted in stripped SG.
so i switch to steel spur gears as well as hardened CB from X SS.
my question is can i use CB bearing as a washer to replace mine that is broken. I did this and the car seems to run fine, but i would like to know if this would be ok.
if i am not mistakes there was a post here regarding the upgraded washer, but i can not seem to find it.
thanks
thanks
ORIGINAL: tmdz28
Hi guys
thanks
Hi guys
thanks
That would be one of my posts I beleive. Here it is...check it out. http://www.rcuniverse.com/forum/m_57..._2/key_/tm.htm
