what can i do ebay trouble
hi i brought a steel spur gear off ebay and had it all correctly fitted but the screws got ripped out and it was trash within a few tanks. so i sent it back and the bloke is saying i didnt use thread lock when i did and wont give me a refund so £34.99 wasted and i already left feed back when it come
is there anything i can do?
NV
IMO Purchase a few stock spurs.
I dont recommend steel for many reasons, your problem included.
If you have the X chassis and trans box then its a quick easy fix, and cost effective. Steel have there issues and cost alot more to replace. You also run the risk of breaking another part of the drive train.
Stick to the stock spur and keep an extra on hand
thanks. and even if its not his fault hes still lying and claming i did not thread lock it when i did also it was both pieces. it was £34 and i could get a lot of stock spurs for that so ill keep trying and look in to paypal complaints
Wasting your time ,thats user error.
If the holes are stripped ,and the screws are gone ..CA tire glue it as 1 piece.
I have ,and am currently still usin a steel spur ,that came loose,and got trashed.
Glue it ...weld it.....or toss it out and get another.
Leave the seller alone...not his fault.
Sorry,but thats the truth.
CS
CS
I have to agree with burn. Those 2 piece gears are so small that even if you did loctite it in there isnt enough threading to hold the screws properly. The solid steel spur that comes with the x-ss is ok, but save your money and buy the plastic ones and make sure its shimmed properly.
WA
Get a Robinson Racing Steel spur (it's 1 piece) I love mine. I saw that problem and didn't have to see it happen. I thought I had enough lose screws to check for (including the operator) that I counted the two piece out.
ORIGINAL: help-me
ORIGINAL: gravediggerracing
Ebay and Paypal will both side with the seller based upon what you have told us. The issue of threadlock won't matter to them. Now, if the gear you got happened to be all chewed up and destroyed, etc and it was auctioned/sold as new, well, then you'd have a case against the seller. It takes that kind of thing (amongst others) to get the attention of Ebay and Paypal.[8D]
ORIGINAL: help-me
If you ask me, you should be complaining to the manufacturer, if anybody. Or just chalking it up as a life lesson that just because you spend a lot of money on something does not mean that it is necessarly better than something that's less expensive.
