HPI Monster Truck Forum Talk about HPI monster trucks here. The infamous Savage 21, SS, .25 or any other HPI MT. You can optionally discuss HPI in our general MT discussion forum if you prefer.
spur gear and clutch bell
Old 05-17-2007 | 09:21 PM
Default spur gear and clutch bell
i have an axial 32 i was wonder what is the best spur gear and clutch bell combo to use with this motor
Old 05-17-2007 | 09:48 PM
Default RE: spur gear and clutch bell
ORIGINAL: sea1107
I would say that the stock bell would do you fine. Maybe think about another size CB...
Just replace the shoes with your fav composite shoe set.
I like the 1.1mm springs. Ofna and Mugen both make a set. you can get gold ones too.
hope this helps
Old 05-18-2007 | 10:00 AM
I'm using 48T/16T with my axial .32and love it. I've also used 46-48t/14t with lots of good low end. I'm running steel but lots of people still use stock. If buying steel buy a Robinson 1 piece and not a 2 piece they'll just give you a headache. If you have the duel disk brakes don't go 46-47/14 because the cb will rub on the disks. The spurs 46-48 are good all around and change the cb for more speed or torque. I've used 14-17 cbs and a 16 is a good all around for your .32.
Old 05-18-2007 | 10:05 AM
black mamba's Avatar
17/47 would be where I'd start out. You're going to have a hard time keeping those front wheels on the ground with all the torque that engine puts out.[8D]
Old 05-18-2007 | 12:34 PM
46u's Avatar
46u
ORIGINAL: myrcsupply
ORIGINAL: sea1107
Composite not me!!!!!!!! [X(]The only spur I ever had a problem with in over 7 gallons was do to composite shoes slipping so much it heated up the CB and melted my spur!!!!!!!!! [sm=spinnyeyes.gif]ALLOY is the only way to go in my opinion!!!!!!!!
Old 05-22-2007 | 12:02 PM
My Feedback: (-2)
47 and 17
Old 05-22-2007 | 08:35 PM
SAVAGEJIM's Avatar
Try the Axial 22T CB and a Robinson Racing 46T steel spur!
Just kidding, an Axial .32 would probably be happy with at most an 18T CB & 49T spur. You will still be able to pull wheelies easily, especially with a spd tranny and 5.75in diameter wheels.
