HPI Monster Truck Forum Talk about HPI monster trucks here. The infamous Savage 21, SS, .25 or any other HPI MT. You can optionally discuss HPI in our general MT discussion forum if you prefer.
savage x hang time
Old 05-18-2007 | 05:50 PM
Default savage x hang time
Hey guys,
I am really starting to like the Savage X, thinking of buying a X 4.6 when it comes out. I have never seen a X run in person though. For you savage x owners out there. How's the truck in the air? Is it a constant battle to control the trucks attitude while grabbin huge air? Seems like a lot of videos out there show the X landing on its rear most of the time. Are the brakes that weak to not bring the nose down if you need or want to?
Old 05-18-2007 | 06:34 PM
Savage_mt2_Attack's Avatar
Default RE: savage x hang time
I dont have a problem contolling my x in the air, but the stock brakes do suck pretty bad. You need to upgrade to the dd brakes and a new servo. If you do get the x 4.6, i dont think that braking will be a problem.
Foxy's Avatar
No, the drivers are noobs. It's one of the better 'flyers'.
To be fair though you need a pretty powerful engine to do it effectively (change attitude in the air or do backflips) but with a well designed ramp and a quick throttle finger and it's no problem.
Stock brakes are rather weak, but if you have the dual disc brake upgrade (standard on the X SS and probably the new X4.6 RTR as well), then it's actually easier to do forward flips than front, as long as you carry a lot of speed onto the ramp.
Old 05-18-2007 | 06:36 PM
ha... i beat ya to it
Old 05-18-2007 | 06:37 PM
Foxy's Avatar
ORIGINAL: Savage_mt2_Attack
lol Git.
Old 05-18-2007 | 06:51 PM
Thanks guys. Looks like I'm getting a Savage X 4.6 RTR when It comes out
Old 05-18-2007 | 07:16 PM
The_Lost_Otter's Avatar
Power is every thing, But i can do backflips with my stock losi 8ight rtr.
Old 05-18-2007 | 11:50 PM
ThunderbirdJunkie's Avatar
ORIGINAL: kdfi
Get it, feller! do up your pre-order on tower now!
Old 05-19-2007 | 08:32 AM
Vigilante212's Avatar
You need a ramp that can give you decent shock preload. A steeper incline helps this I just have this POS ramp thats straight and about 8" high on the end I can jump fine until about 3/4 throttle then I have problems keeping it level, probably because im still learning though. Then again I dont use that much throttle to hit a jump at the track anyway.
Old 05-19-2007 | 10:53 AM
rcnitrohead's Avatar
Ive found my Savage to be an awesome jumper. This is due to the really long shocks 13lb weight (which helps a lot when it comes to stability) and the soft stock tires. Jumping it is really fun unlike my T-maxx which is unpredictable and breaks after every 2' jump. You should definitely get the DD brakes unless your going for the newer versions. They are pretty strong.[8D]
