HPI Monster Truck Forum Talk about HPI monster trucks here. The infamous Savage 21, SS, .25 or any other HPI MT. You can optionally discuss HPI in our general MT discussion forum if you prefer.
What to buy for my savage?
Old 05-19-2007 | 04:00 PM
Savage_mt2_Attack's Avatar
Default What to buy for my savage?
Well my birthday is coming up, and ill have like $700 to spend. I plan on ordering stuff soon so that ill have all the parts by summer since i live in Canada. What are some good upgrades to buy for my truck?
I already have:
-3 speed
-dual disk brakes
-big joe tires
-ms airfilter
-"custom" ofna linkage
-high torque throttle servo
-HD dogbones
Old 05-19-2007 | 04:37 PM
CWC
Default RE: What to buy for my savage?
Get a second savage or some of those nice tvps from that guy on this forum whats his name? J/K. I must say it's your $700 bucks but spend wisely $700 is a lot but can go very fast on just a one or two big buys like 2 new EB nova .28. My personal list is; new TVPs, full set of rpm arms or CF arms, new rims & tires, body, ring & pinion (HBC9009, HBC9010), nomraido react, raido box cover (hpi#7121) and a few other things that I can't think of.
Old 05-19-2007 | 05:11 PM
Well some of the things i wanna get are:
-mugen alum. shoes & springs
-ofna hump pack
-rpm centre skid plate
Is this flywheel any good?
http://www2.towerhobbies.com/cgi-bin...?&I=LXKAY8&P=7
I am also considering buying the new axial .28rr engine.
But that still leaves me with a bunch of unspent money
Old 05-19-2007 | 06:13 PM
poe
My list would be:
-Chronic's LCG extended TVP's..
-New body
-Proline Badlands and rims of your choice
- LRP Z28 or STS 30
- Upgraded drivetrain
- Aluminum clutch shoes
- aluminum pipe
- hump pack (fo sho)
- get yourself some new shoes... whatever.
- something goes here
- and here
Old 05-19-2007 | 08:43 PM
rcnitrohead's Avatar
Wow, I wish I got remotely that much for my birthday[&o] Definitely get a hump pack and think about Chronics LCG TVP's!
Old 05-20-2007 | 12:26 AM
Hump pack
Chronic TVPs
LST shocks and kit
Futaba 3PM FASST
STS D30M Rev 2
Axial beadlocks
40 series tire
And a whole bunch of little goods.
-Josh-
Old 05-20-2007 | 01:29 AM
Get the extended tvps cause these things always want to flip over.
Old 05-20-2007 | 10:29 AM
LSTVega28's Avatar
I honestly would get the Picco .28 over the LRP....
Old 05-20-2007 | 11:14 AM
black mamba's Avatar
$700? That's a lot for mods. If you are smart and spend wisely, you can modify your Savage to improve performance/looks AND still be able to get another truck if you so desire.[8D]
Old 05-20-2007 | 11:51 AM
if i get the aluminum shoes, do i have to do anything to them or the clutch bell before i put em in. (scuff them up etc.) As well, how often do u need to file down the edges.
Old 05-20-2007 | 04:40 PM
No install prep needed, just install them out of the bag. As for maintenance filing, that all depends on how much you use your truck, etc.
Old 05-20-2007 | 05:02 PM
k sweet.
is that robinson vented flywheel any good because im getting fed up with the stock flywheel... the pins have gotten loose on me a couple of times now.
Old 05-20-2007 | 05:12 PM
Put the money in the bank!!
Old 05-20-2007 | 11:21 PM
ThunderbirdJunkie's Avatar
I'd honestly replace that MotorSaver air filter if you get another engine. the stock Savvy LE/X/4.6 air filter is about the best you can get as far as filtration goes.
Also...$700? HOLY MOSES, last time I got that much for my birthday was....well, never you be rollin in dough!
Old 05-20-2007 | 11:31 PM
thanks... i wouldnt have guessed that
i'm hoping to get an axial .28rr when they come out in stores
Old 05-21-2007 | 12:29 AM
ORIGINAL: ThunderbirdJunkie
Why? It can't be from a lack of filtration. I've had my truck literally buried in a super fine, silty dirt/sand mix and everything on/in the truck was just caked with the stuff, air filter included. To make a long story short, the filter looked horrible and I expected the worst when I removed it, but when I pulled it off the carb there was 0 dirt in the intake tube and carb venturi. The dirt never got past the inner mesh-the inner foam was still clean. Recently this kind of terrain is normal for me and I've yet to find dirt where it shouldn't be. If it will pass this unoffical filtration test, it will pass anything. I'd recommend the Motor Saver to anyone in a heartbeat.[8D]
Old 05-21-2007 | 12:30 AM
My issue with the motorsaver is this...
when you wash/reoil an air filter element, they shrink. instead of shrinking AROUND it though, the foam shrinks inside the filter cage on the motor saver, which CAN, theoretically, allow dirt and all kinds of nasty **** in your engine.
Theory or not, I don't like those odds[&:]
Old 05-21-2007 | 10:43 AM
I'll have to watch out for that. Thanks for the heads up.[8D]
Old 05-21-2007 | 11:37 AM
np dude. I noticed it the first time I washed a motor saver element...chcuked it in the trash. luckily it was with my XTM 247 and not something that's less tolerant of abuse
Old 05-21-2007 | 11:45 AM
I bought a motorsaver for my Savage... ended up putting it on the LST2 because it didn't look any better than the stock HPI filter. I cut some of the little bars off of the "cage" that the stock filter element goes over, just in case it was a restriction, but it's fine the way it comes.
