HPI Monster Truck Forum Talk about HPI monster trucks here. The infamous Savage 21, SS, .25 or any other HPI MT. You can optionally discuss HPI in our general MT discussion forum if you prefer.
blue thunder fuel
Old 05-20-2007 | 05:36 PM
jumpin_high's Avatar
Default blue thunder fuel
with blue thunder fuel whats the difference between the sport fuel and the race fuel
Old 05-20-2007 | 05:47 PM
rclynx's Avatar
Default RE: blue thunder fuel
Oil content and % methol alcohol (nitro)
Old 05-20-2007 | 05:52 PM
so which is better to use?
Old 05-20-2007 | 06:07 PM
rclynx's Avatar
HPI ? 20% with not over 12 oil lube factor. My 2 best sellers are Bluethunder 20% and WERKS 20%................I use WERKS for my own trucks and cars[:-]
Old 05-20-2007 | 06:45 PM
black mamba's Avatar
Sport if you are just driving around the house and don't want to spend a lot on fuel. Race if you want a bit more power and don't mind the added expense.
Old 05-20-2007 | 07:39 PM
rclynx's Avatar
[sm=confused.gif] HUH [sm=confused.gif]
Old 05-20-2007 | 07:52 PM
SAVAGEJIM's Avatar
The "sport" is what I used to run in my bashers; it is too high of oil content which resulted in gummed up and slipping one way bearings. I had to disassemble and clean the engine thoroughly every 6mo to prevent the slipping (actually, I probably had to clean the OWB more often). The "sport" is by no means a sport blend at all; just a cheap blend marketed for the bashers.
I never used the race blend; but if it is actuall $2-3 more, it better ontain way less oil and be actually bleneded to compete with other race proven fuels such as Byrons.
Old 05-20-2007 | 09:01 PM
ORIGINAL: rclynx
What could you possibly be confused about?[8D]
Old 05-20-2007 | 09:15 PM
Vigilante212's Avatar
The sport stuff also contains a additive that coagulates the fuel if your engine gets above 300 degrees I think.
