HPI Monster Truck Forum Talk about HPI monster trucks here. The infamous Savage 21, SS, .25 or any other HPI MT. You can optionally discuss HPI in our general MT discussion forum if you prefer.
gear mesh
Old 05-22-2007 | 08:40 PM
Default gear mesh
i was wondering if this looks like a good gear mesh?
ID:	689742   Click image for larger version
Old 05-22-2007 | 08:41 PM
aer-wubby's Avatar
Default RE: gear mesh
Well, hold the clutchbell down and move the spur slightly. There should be a small amount of play between the meshing teeth.
Old 05-22-2007 | 08:47 PM
SAVAGEJIM's Avatar
ORIGINAL: dwc1984
Use the paper strip trick. Take some paper and cut a strip that is the width of the spur hear and with the CB and spur in place at a guestimated mesh, turn the spur and feed the paper in. Then, pinch the engine mount closer to the left of the savage such that the CB gear presses the paper all the way against the spur gear with only the paper in between the teeth. This is the proper mesh. Lock doen the engine mount and take out the paper strip. Turn the spur by hand; this is how the gear mesh should feel on a brand-new spur and CB. (A used spur and CB will feel differently from the tooth wear).
Old 05-24-2007 | 02:24 AM
carldav's Avatar
Hi SAVAGEJIM
I also use the paper mesh trick. However I usually fold two sheets of paper then I insert it Between the Spur and CB. Is this safe or should I just use single paper?
Old 05-24-2007 | 08:37 AM
HPI instructions say two sheets. Thunder Tiger instructions were one sheet and either way has worked fine for me. Just make damn sure that the motor is parallel (looking from the top and from the side) with the spur shaft. If not, it won't matter what your gear mesh is.
Old 05-24-2007 | 12:10 PM
How did you get your engine to mount on the other side?
-Josh-
Old 05-24-2007 | 01:50 PM
black mamba's Avatar
ORIGINAL: aer-wubby
Ditto
