 Problem with Jet Tronic Dual Valve >
Old 06-30-2007 | 05:15 PM
Default Problem with Jet Tronic Dual Valve
Hi Lads,
I have a brand new Jettronic Dual Valve installed in a XL, I have just programed it as per the instructions, and it is switching fine. Port 1 is connected to the air tank (with fill) and 2 and 3 are connected to the gear.
When ever I put some air in the system, it just rushes out of somewhere! After further investigation, it is coming from the valve somewhere! When I clamp the air in tube (to port 1) the pressure builds up fine, as soon as i remove the clamp, the air rushes out from (what seems like) the port above it!
Operating the valve makes no difference!
Any ideas?
Old 06-30-2007 | 11:26 PM
Default RE: Problem with Jet Tronic Dual Valve
pm lov2flyrc here or call todd at dreamworks.. he is a whiz with the jetronic valves, since he sells the whiz out of them.. they are the only way to go..
Old 07-01-2007 | 03:57 AM
TREADSTONE's Avatar
Volkan..
i had exactly the same problem with a Jet-tronics valve in the BI...Had a quick chat with Dave wilshire ...he said send it downand they would check it over ....they did and found a fault internally..sent me a new one by return of post..Great srvice ...as per usual...
Old 07-01-2007 | 04:48 AM
Mart (Ham)'s Avatar
I had the same thing two weeks ago, I had a single jet tronic valve that came with my jet 1A retracts just letting all the air go, I explained this to sandor at Digitech and he said it was faulty and promptly replaced it, great service from him to.
Old 07-01-2007 | 06:08 AM
Cheers for the info! I replaced it with a spare I had, and all is good!! Cheers.
