 Digital high torque or high speed servos >
Old 07-01-2007 | 09:29 AM
Default Digital high torque or high speed servos
I am in the process of buying all the components for my first turbine Jet. NitroPlanes Falcon120 and JetJoe1400. Futaba 3151s will be going in the flaps and rudders. I want to put digital MG servos in elevator and ailerons, should I get high speed or high torque digital mg servos for these control surfaces?
Thanks in advance for any input/sugestions.
Matty
Old 07-01-2007 | 09:44 AM
Default RE: Digital high torque or high speed servos
Correction, probably go with JR DS821s for the rudders and flaps.
Old 07-01-2007 | 12:00 PM
High torque, is more important...
Regards
Old 07-01-2007 | 12:57 PM
erbroens's Avatar
Ditto...as well the servo linkage geometry. I also prefer to use metal gear servos on jets.
Enrique
Old 07-02-2007 | 06:55 AM
My Feedback: (14)
You mentined that this is your first turbine project. The Nitro falcon is not designed for turbines. You have to do several modifications to fly it with turbine. Also the JJ engines don't have the best reputation. I understand that this is a low budget project to enter into turbines. But If you can't find wich are the better servos to fit this project, I recomend you to get all the help possible from an experience turbine pilot near you. Take all the extra precautions in the modifications of the plane to ensure safe flying. About your engine choice, I have a friend that was trying to start his for a long time. Well he finally did start the engine and was running great. Until the day he try to maiden his tango. Doing some taxi testings in the runway in the acceleration spool the engine just quit after reaching 1/2 to 3/4 throthle. A lot of work and still no running. His solution was very simple. He now put an old ram 500 and just got two succesfull fligth with no problems at all. I wish you the best luck in your project.
Rgs
Alejandro
Old 07-02-2007 | 10:45 AM
My Feedback: (10)
You should probably read the latter of the JJ engines thread here on RCU. They seem to have gotten the bugs worked out on this engine.
