 Home made Jetcat data cable >
Old 07-10-2007 | 02:54 AM
Default Home made Jetcat data cable
Having just started my second Jetcat installation and remembering the pain of trying to hide all the data cable on the previous model I thought I'd make up my own to the correct length. I have read the horror stories about blowing ECUs but after a bit of research it really doesn't look too bad.
First problem was to get the correct bits.
The jack is often refered to as a RJ11 jack but this is not entirely correct. The connector is the same size as for RJ11 but may or may not be the same. It needs to have 6 contacts and the easiest way is to look for a connector that is sold as 6P6C (just guessing at what this stands for but I find it easy to remember it as a 6 way plug with 6 connectors).
Next I saw a tester that will check the pins for you after the cable is made. This will check for open and cross-wired circuits and is really cheap. I checked my Jetcat cable with it and the sequence runs from 1-6 so checking the cables that I make should be really easy.
Only things left now are some cable, which is 6 core flat cable exactly the same as the Jetcat cable (except that it is grey and the colour coding is different) and a crimper. I will borrow the latter from a friend for the time being to see how I get on.
It will be a couple of days before I make the cable but I'll report back when it is done. If anyone has any pointers or corrections then that would be appreciated.
ID:	719898   Click image for larger version
Old 07-10-2007 | 03:18 AM
Default RE: Home made Jetcat data cable
I have made several RJ11 and RJ45 patch leads, and I have noticed that the problems start to occur when you use cheap connectors and cheap crimp tools! I have had several cheap chinesse connectors break up or crack! Just be careful and make sure the cable checker gives you the OK! Good Luck!
Old 07-10-2007 | 03:53 AM
From: Auchtermuchty Fife Scotland UK, UNITED KINGDOM
Hi Darren
I can supply Data Cables to any length, for any engine.
Drop me an email with engine type, cable length.
Hear from you.
Ian
Old 07-10-2007 | 03:54 AM
smitty1001's Avatar
My Feedback: (29)
Really all you need is the correct cable now (6 parallel) and you're in business. No worries on the circuit - it is no mystery - just lay the cable flat and crimp one connector on right-side up and the one at the other end upside-down. Works like a charm everytime!
