Hurricane Impellor Adapter Nut Needed!!!
Hello Jet Jocks,
I have two Hurricane impellors to replace Byron fans in my F-16 and Mig-29. But, I am missing the adapter nut that screws unto the OS 91 DF and the bolt that holds the 'spinner cone' on. I was hoping that somone had these parts from a failed or un-needed Hurricane Impellor. I believe the tractor and pusher versions that go on the OS 91 use the same adapter and bolt. I do not have a lathe to make this adapter. It would be easy out a a piece of hexagon brass stock.
Any assistance would be greatly appreciated. I'd like to get this jets in the air. The original byron fans are damaged.
DW_Crash
DW_Crash
My Feedback: (29)
OH
I think I know which nut.. anyway you can post a pic? (might be able to help you out)
Is there any place to buy a hurricane fan anymore? Like to get one for my byron BD-5.
My Feedback: (10)
NE
you can buy huricane fans and parts on the shelf at your favorite lhs, right next to the hen's teeth...LOL good luck on finding parts with out making them. i have been looking for them for quite a while now with very little sucess...
Gents,
The nut looks like the attached picture. It is .950" long with a .250" nut part. The nut part is 0.500" flat face to face. Shaft is 0.4". The bolt is a 1 inch bolt. It is threaded the same as the OS 91. I believe it is 1/4" by 24.
I like to thank a buddy for taking the pic and measurements of his fan adapter.
DW_Crash
DW_Crash
My Feedback: (50)
This is probably late but if anyone needs help, parts or support for the Hurricane Fans let me know and I will put you in touch with the owner.
FYI
James
FYI
James
My Feedback: (49)
Good news, guys. Hurricane is back in business with a new owner. I suggest you contact them
http://hurricanefans.net/index.html
Joe
Joe
My Feedback: (50)
Yeah, Wayne is a good guy and he has been involved in DF for many years. The aluminum hub and Aluminum bearings makes a HUGE difference-
Cheers!
Cheers!
New aluminum bushing $ 7.00
New hub $65.00
New spinner $25.00
Blade repair $50.00
New Byron replacement Impeller $100.00
Shop time for custom work $65.00 an hr.
All plus tax (if applicable) and Shipping (usually about $5.00 in the U.S.A.)
New hub $65.00
New spinner $25.00
Blade repair $50.00
