 AMT Mercury battery >
AMT Mercury battery
AMT Mercury battery
Old 07-15-2007 | 10:55 AM
My Feedback: (51)
Default AMT Mercury battery
Hello guys,
A friend of mine bought a second hand AMT 180 Mercury engine (air start).
Even before he recieves the motor, we would like to know whih battery is needed to run this engine, since it doesnt have an onboard starter ?
Old 07-15-2007 | 11:04 AM
Henk Visser's Avatar
Default RE: AMT Mercury battery
Hi,
You can use a 6 pack nicad or simular.
Or you can use a 2 cell lipo battery 7,2 V this works fine! I use it since one year now And Bennie from AMT said the higher voltage isin't a problem.
Regards, Henk
Old 07-15-2007 | 11:05 AM
You will need a battery to power the ECU. Either 7.2 ( 6 Nicads at about 12-1400 mah) or 9.6 volts. We have used 7.2 volts for years without any problems.
Jack Mathias
Evansville IN
Old 07-15-2007 | 11:10 AM
My Feedback: (51)
Will a 7.4V Fromeco Li-ion pack 2600Mah work well ?
Old 07-15-2007 | 11:53 AM
yes it will work fine 7.4v isin't a problem[8D]
