Jet-tronic retract valve
IN
Does anyone have any experience using the Jet-tronic retract valve with a air up / spring down system..I'm trying to use this valve with my Jet-1A retracts for my new boomerang and can't get the valve to work properly...The Jet-1A's only have one inlet (festo fitting) for the air supply ... Thanks,
IN
No but I bet that is the one I need!!! I just realized that I probably need the single action valve..I'm used to using that valve for a brake valve not for retracts...Thanks for the reply..
AE, US MINOR OUTLYING ISLANDS
yep, single action jetronics work on jet-1a's and brakes and imo they are the only way to go, .. u can set the brakes to pulse or anti- skid or auto brake as I like to call it.. and u can also double duty channels with them, like- smoke on 1st half of a slider and brakes on 2nd, both on 1 channel, ect., ect.. here's a saying I've heard- "if ur not using jetronics valves you must be living in a cave".
