 Throws and CG needed for a JHH A7 Plz >
Old 07-20-2007 | 06:30 AM
My Feedback: (59)
Default Throws and CG needed for a JHH A7 Plz
If anyone could give me the throws for a JHH A7, would be great. I hope to put a maiden flight on one that has been converted to a prop bird later today! I know, why would you convert one to a prop? I got it from a friend who crashed it on its first flight. I had hopes of fixing the damage and putting a MW 44 in it, but once I got into the repair job I found the damage was much worse than I thought.
Now it looks like a big HOB A7
Thanks.
Joey
Old 07-20-2007 | 09:56 AM
Default RE: Throws and CG needed for a JHH A7 Plz
Joey,
The airplane is CG'd by lifting the aircraft up by the LE of the sawtooth with your fingers. The airplane should be level or slightly nose down when you do this. I don't remember the control throws off hand though. Best bet would be to call the shop (562-467-0260)
Chris
