What glow plug to use for turbine engines?
My Feedback: (67)
Hi All, what type of glow plugs do you recommend for the following engines?
1. Wren 44, 54?
2. JetCat P60, P80, and P120?
3. Artes Super Bee?
It seems to me sometimes I can get good starts when I place some plugs over the other, but I don't have records of what types of glow plugs that mine are.
Any special care do we need to do?
Mike
1. Wren 44, 54?
3. Artes Super Bee?
Mike
I use Mccoy #9 in my Wren engines. I just make sure I have two full coils pulled out. The Mccoy seems to have a thicker element.
Regards
Regards
I 'm using a NGK 44. with a diamond tip from my chevy. took some modification to work and only added 4 pounds in weight .
Can someone tell me why the plug makers don't make a special "Turbine Only" plug. Normal glow plugs are made using Platinum that reacts with the methanol in the fuel. We don't need platinum just a nice hot element. It can be anything just as long as it can stsnd up to the heat in the combustion chamber.
They could be made cheaper and made of thicker wire with the coils already exposed.
Just my 2 cents worth.
ORIGINAL: TommyWatson
Kelly
Thanks in advance.
NY
Tommy,
Actually a "Turbine Only" glowplug is made Aldon Kelly, aka Merlin Glow Plugs, Inc. in the USA. This plug has an extended nose to position the element deep within the combustion chamber of model turbines. It is available with either platinum or nichrome elements. They were sold some time back by Carlos V. and DreamWorks. I've had best success with the nichrome element in my FTE and RAM turbines and having Al produce some more for me.
Rgds,
Art ARRO
Rgds,
Art ARRO
NY
Craig,
Most gas start model turbines use a standard 1/4 x 32 thread glowplug developed for model glow fueled engines. Artes/Jet Central utilize an internal ignitor to initially ignite the gas for the turbine start process. Some specialty glow engines use- ie, Nelson, a non-standard thread or a retainer nut to secure the plug to the engine. I don't know if any of these special plugs used in model gas turbines. With the advent of kero starting, most turbine manufactures developed their own ignitors, either internal, like JetCat or external like the early Wrens. Trust this answers your questions.
Rgds,
Art ARRO
Rgds,
Art ARRO
FL
I use Rossi R-8 plugs.
See the attached photo for the modified element. Apply 1 1/2 volts until it is bright orange,(to anneal it) remove the voltage, then using a straight pin, tease the element out until it looks like the one in the photo.
