Fuel Valve nipples
ORIGINAL: voodoodb
Anybody know where I can get soem of the screw in nipples for the fuel and gas valves> I have the jetcat valves, and have broken one of the nipples. I called Jetcat, but they didn't have any.
Doug
Doug
festo M3 to 4
ORIGINAL: Steve Collins
If you are talking about one of the small pressed on nipples coming loose, push it back in and then use a green, penetrating threadlocker. I had the same thing happen to one of my valves but this fix is working pretty good.
on the new valves they are threaded
