 jet joe starter motor replacement? >
Old 09-26-2007 | 06:59 AM
Default jet joe starter motor replacement?
Looking to replace the starter motor with a better one and one that will work more than 2 starts. Can any tell me which would be a good one to use?
Thanks Todd
Old 09-26-2007 | 10:03 AM
My Feedback: (51)
Default RE: jet joe starter motor replacement?
i just use any 300 motor i could find. works perfect.
Old 09-26-2007 | 01:09 PM
Banned
The jetjoe is a 6v starter motor..it will only last two starts if you put 12 volts to it.
(RK 370SD) is the number thats really hard to read on the side of the motor.
Old 09-26-2007 | 07:25 PM
Ruizmilton's Avatar
My Feedback: (29)
Todd;
Order great planes part number GPMG0310 from Tower, T-370 6.0-9.0 volt motor, You'll need to grind the oustide a bit for it to fit properly, It's the oen that I have used and last a lot longer than the stock motor, I belive thay are $7.99.
Old 09-30-2007 | 10:53 PM
Todd,
I used a Graupner Speed 280 6V motor to upgrade the one that came on the JetJoe JJ1400. I also use this with my WREN. They will spin a 14 lb class turbine up to around 28K or more. And. they are very durable.
DW_Crash
Old 10-01-2007 | 02:12 PM
Banned
I'll have to try the speed 280 next time I start playing with the starters.
Old 10-01-2007 | 02:13 PM
Thanks Guys..Todd
