 Anyone know were to get these quick release >
Old 10-15-2007 | 08:58 PM
WhoDaMan's Avatar
My Feedback: (164)
Default Anyone know were to get these quick release
Any body know were to get these puppy's
Thank you
Old 10-15-2007 | 09:53 PM
dbarrym's Avatar
My Feedback: (47)
Default RE: Anyone know were to get these quick release
Don't know those exact fittings, but they look like 3mm airline disconnects...Dreamworks has several that look very similar in the air system accessories section.
Barry
ID:	783867   Click image for larger version
Old 10-15-2007 | 10:00 PM
My Feedback: (15)
Those look more like Clippard pheunmatics
Old 10-15-2007 | 10:31 PM
WhoDaMan's Avatar
My Feedback: (164)
I have a clippard book but I can not find them there,,,, They disconnect so nicely
Old 10-16-2007 | 12:42 AM
Shaun Evans's Avatar
Dave,
They don't disconnect as well as those BVM ones! I don't remember what they're called, but they sell them for the Bandit. I've been using them on wings with gear in them ever since I saw them--especially on my last four Starfires. You never have to touch them, just loosen the wing screws (or clamps) and pull the wing off. I do the same thing with the servos. No leads to mess with at all.
Old 10-16-2007 | 01:32 AM
mick15's Avatar
Those fittings were used by Sophia on their J850, can't tell you more than that.
m
Old 10-16-2007 | 01:42 AM
My Feedback: (10)
ORIGINAL: WhoDaMan
Thank you
dont use them they are crap.
i used to sell them , they work fine at start but they dry up .
and can just disconnect , while using them.
use robart connectors instead e made/ teflon seal , can never go wrong..
Old 10-16-2007 | 06:47 AM
GrayUK's Avatar
I think 'they are crap' is a bit over the top.
I have been using them for fueling for 10 years and wish i knew where i could get some more!
Old 10-16-2007 | 07:04 AM
You can get them here:
http://www.jetpower.at/
Wren sells them as well (http://www.wrenturbines.co.uk/). They are used to feed the propane to the turbine during the start up procedure.
I've been using them for quite some time now. Never had an issue.
Yann
Old 10-16-2007 | 07:10 AM
My Feedback: (10)
ORIGINAL: GrayUK
ok "they are not good at all for what you pay for them"
does that sound better?
you are using these 3mm conectors for refueling?[:-]
Wren still sels them , i think they came of rectus in germany.
and how much do they cost ?
for the same money you can have 4 robarts self sealers
Old 10-16-2007 | 07:31 AM
seanreit's Avatar
My Feedback: (60)
One suggestion from Mcmaster:
4 51525K211 1 Pack Plastic Quick-turn (luer Lock) Coupling, Nylon, Female X Barb, For 1/16" Tube Id
5 51525K121 1 Pack Plastic Quick-turn (luer Lock) Coupling, Nylon, Male X Barb, For 1/16" Tube Id
Old 10-16-2007 | 01:39 PM
GrayUK's Avatar
Digitech
Like i say, they work OK for me, no issues neat and good value when they last as long as they do...must call Wren.
paul
Old 10-16-2007 | 01:51 PM
Undecided's Avatar
My Feedback: (36)
See if these will work
http://www.mcmaster.com/ctlg/DisplCt...MainWidth=1068
Neal
Old 10-16-2007 | 01:57 PM
WhoDaMan's Avatar
My Feedback: (164)
200 hundred flights and no failures ,,, seem to work well I like being able to just pull and release
Old 10-16-2007 | 02:40 PM
NickC5FE's Avatar
My Feedback: (31)
Well they may have been crap in Sofia's use but they work great on air systems.
Those Mcmaster's look the piece. I have been looking for them ever since i had the Euro
Old 10-16-2007 | 04:32 PM
This is what I use:
http://www.coleparmer.com/catalog/pr...sp?sku=0636065
Both the male and female fittings have internal valves that shut off flow when disconnected.
Old 10-16-2007 | 04:45 PM
P38J's Avatar
My Feedback: (14)
You can find them at http://www.beswick.com they have the quick disconnects your looking for.
Old 10-16-2007 | 04:51 PM
FL510's Avatar
My Feedback: (8)
Here's another type that is close.
http://rcscaleproducts.com/retract_acc.htm
