 KINGCAT FUEL CELLS >
KINGCAT FUEL CELLS
KINGCAT FUEL CELLS
Old 10-16-2007 | 05:12 PM
Miguel Santana's Avatar
Default KINGCAT FUEL CELLS
About the Kingcat...
I wonder how much capacity has the 2 mains tanks?
I´ll be using a P-120...so I´m considering the eliminate the 16oz hopper tank...
If there other reason than increasing fuel capacity to use this hopper tank?
BTW...I'm having fun putting this bird toguether...and so far haven't done any modification [&o]...everything is so neat and clean...
Miguel
Old 10-16-2007 | 05:21 PM
jkeze's Avatar
My Feedback: (36)
Default RE: KINGCAT FUEL CELLS
MIguel:
I built mine with only the 2 main tanks and the UAT. I fly for 7 minutes from geat up to gear down and I still have a lot of fuel left. I thought the instructions said with all 3 tanks and the UAT there was something like 150oz. Minus the 16 oz SUllivan boat tank still leaves a lot of fuel and fun.
JK
Old 10-16-2007 | 05:28 PM
Great....Thanks
Old 10-16-2007 | 05:40 PM
whaledriver's Avatar
My Feedback: (154)
Mine has the hopper tank for smoke. Two more hopper tanks behind the mains for smoke as well...in series.
Old 10-16-2007 | 06:19 PM
As I recall, the KingCat fuel system total is 4.8 litres (or, 162.3 oz). Rounding down, 162 oz.
Deduct the 16 oz. header, the 4 oz. UAT, and you have 142 oz. in the mains....so, each main tank contains 71 oz.
I have a P-120 in one of mine, and I set the timer for 10 minutes, then land. That amount of time leaves enough gas for a couple of go-arounds.
I also have a newly finished one powered by a Titan, but haven't flown it yet.
Harley Condra
BVM REP
JetCat REP
Old 10-16-2007 | 06:30 PM
Harley,
Your 10 minutes with the p120 make more sense to me ...
Locally a buddy of mine has his KC set to 12 minutes with the hopper in it.
I will save the hopper tank space for 20oz smoke tank
Regards,
MS
Old 10-16-2007 | 06:35 PM
bcovish's Avatar
My Feedback: (8)
MS
Gary Mueller makes a 48oz tank that will fit between the two mains on the KingCat.
Old 10-16-2007 | 08:40 PM
Miguel,
I feel that it is safer to land with a little excess fuel aboard than to run dry during a go-around. Been there, done that. I have used the space behind the fuel cells (behind the aft spar) to contain two 16 oz. Kraft-Hayes tanks in series for the smoke fluid. Only 32 oz. of Smoke oil doesn't last long, but it's better than nothing.
Harley Condra
BVM REP
JetCat REP
Old 10-16-2007 | 09:27 PM
with a titan how much time will you have?
