domler sachs enigne
My Feedback: (15)
VA
hey guys i have an older sachs engine twin cyl. and im in need of upgrading the ignition system please point me in the right direction as cost efficient as possible
ORIGINAL: icando3d2
BTW, It is Sachs Dolmar.
My Feedback: (15)
VA
this is the engine that i have
3.0 CU. IN.
Twin Cylinder
PK Plus 20x10 @ 6300 rpm
Single Carburetor
25 lbs. Thrust
93 DBA
Weight=4 lbs.
Muffler Mount System
Isolation Mounts
Velocity Stack
Crankcase Pressure Tap
Electronic Ignition System with Auto Advance Timing
Backplate 4" in Diameter
7 1/4" from Firewall to Prop Hub Face
8 1/2" from Spark Plug Tip to Tip
$675.00 USD
3.0 CU. IN.
Twin Cylinder
Single Carburetor
25 lbs. Thrust
93 DBA
Weight=4 lbs.
Isolation Mounts
Velocity Stack
$675.00 USD
