Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Gas Engines
 I need help tunning. what temp should i be at. >
Old 05-17-2008 | 12:33 PM
Default I need help tunning. what temp should i be at.
I have a sport Werks Turmoil .26 motor. Im have a hard time tuning this motor. i broke in the engine 6 tanks of fuel. i noticed the fuel loads up in idle at times. how can i get this back where i need this buggy. should i start over and go to 3 1/2 turning on the high side on carb?
Old 05-17-2008 | 06:42 PM
Nathan King's Avatar
Default RE: I need help tunning. what temp should i be at.
Start with the factory settings. Make sure the high end is a little rich of peak and adjust the low end again. It sounds like you have a rich low end to me.
