Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Gas Engines
 nx props, any good and where to get at ? >
Old 06-20-2008 | 03:55 PM
My Feedback: (15)
Default nx props, any good and where to get at ?
Hey there, Im looking at maybe purchasing a couple nx props to go on a brillelli 46.
Where do y'all buy them from at a good price?
John
Old 06-20-2008 | 04:33 PM
Default RE: nx props, any good and where to get at ?
Air Wild is the primary distributor. The price is whatever they charge, be it good or bad. Nice props though.
Old 06-20-2008 | 04:35 PM
My Feedback: (15)
Thanks Pat, I just wasnt sure where to get them from.
I'll order me a couple and give them a whirl.
John
Old 06-20-2008 | 06:41 PM
Nice play on words
Old 06-20-2008 | 07:00 PM
My Feedback: (15)
Hehehe, thanks Pat.
I ordered me a 20x10 as well as a 21x8 NX.I know I will just have to bolt them on and tach them to find out , but which one do you guess is going to give me better speed? Its going on a Brillelli 46, and I cant go bigger than a 21 inch prop due to ground clearance on my Skyshark Christen Eagle ( 64 inch wingspan) "hopefully" coming in around 15 lbs- I still have to bolt the Brillelli on and test it once I get the new props.
Thanks again,
John
Old 06-20-2008 | 08:05 PM
The 10 pitch with the smaller diameter should provide more speed but I would still try them both. Depending on your flying style you may like the larger 8 pitch better, but both are a little short, imo. You won't know until you try though.
Old 06-20-2008 | 08:34 PM
Rcpilot's Avatar
My Feedback: (78)
I think you're going to like the 21-8. My Fox 3.2 (52cc) was turning it at 7600RPM and flying the GP 1/3 Pitts around pretty darn good at 18lbs +/-
Old 06-21-2008 | 01:07 AM
Kinda what I was thinking. The 20-10 will go a bit faster but it's going to take awhile to get up to speed because of the diameter.
Old 06-21-2008 | 09:08 AM
Bob Pastorello's Avatar
My Feedback: (198)
ORIGINAL: JohnMcGowan
John
I've had a couple of these engines. They did VERY well with the NX 21 x 8. Personally, I wouldn't load that engine much more than that. The NX 21 has great spool up, good thrust, and acceleration is pretty instantaneous on this engine. A 22" would just be too much load, IMO.
Airwild seems to do the best of keeping the NX in stock. And they ship promptly.
Old 06-22-2008 | 08:38 AM
I use the 21-8 Xoar on my B-46...seems to be in the right range...
Just for clarity, you are using a 21-8 prop on a 53cc engine? I would think a bit light for that displacement...
Old 06-22-2008 | 03:18 PM
yarom's Avatar
My Feedback: (82)
It's the right size prop for the Brillelli.
I have played a lot with NX props in different sizes with mixed results. I suggest you try the NX and compare them to the Xoar and menz, to find what you like best...
Hehehe, thanks Pat.
Thanks again,
John
