ZDZ plug cap
Old 06-22-2008 | 08:30 PM
My Feedback: (27)
Default ZDZ plug cap
Can the plug cap on a ZDZ 80rv ignition be replaced and if so where? Thanks Gary
Old 06-23-2008 | 08:46 AM
RC Extreme power's Avatar
My Feedback: (24)
Default RE: ZDZ plug cap
That is one of the problems that the ignition has had in the past is the cap would fail, I don't know if the cap can be replaced or not but try and give RC showcase a call, I know a lot of people are changing there ignitions over to the RCxel because it can be done cheaper than replacing the stock ignition.
Milton
Old 06-24-2008 | 05:15 PM
My Feedback: (27)
I called C.H. IGNITIONS and they have a replacement cap that is made more like the DA cap just have to get a new plug and not cut the tip off. I have one on the way. thanks for the info. Gary
Old 06-25-2008 | 02:25 AM
Oilsands's Avatar
What plug are you getting?
Old 06-27-2008 | 11:56 AM
My Feedback: (27)
NGK BPMR6F is what I use. It is the same as with the ZDZ cap just don't cut off the end like you do for the ZDZ.
Old 07-03-2008 | 11:35 AM
My Feedback: (27)
I have replaced the plug cap on my ZDZ 80 and it works great! $15 is much cheeper than a new Ignition.
Gary
