Help, this should be easy.....
Old 05-12-2003 | 06:50 PM
Default Help, this should be easy.....
When I hooked up my car for the first time I was able to set up the speed control OK but my servo is turning my wheels all the way to the left and making some screech noise. Can someone tell me what I am doing wrong.
Thanks for your help
Old 05-13-2003 | 08:35 AM
Cactus.'s Avatar
unscrew your servo horn and remove, turn on the radio and centre the sticks and trims, center the horn and screw back on.
sounds like you missed this simple step and the servo was trying to find center. always fix horns with the servos on so you know they are centered
Old 05-14-2003 | 12:27 AM
Default Thanks
This worked great! Thanks for the help!
Old 05-14-2003 | 07:45 AM
Cactus.'s Avatar
no problem
