Foam inserts
Old 05-18-2003 | 11:09 AM
Default Foam inserts
I am going to buy a HPI Type SS soon, and I am confused about tires. So here are my questions:
1. Is it possible (and good) to glue the tire to the rim without using a foam insert?
2. Do you have to glue foam inserts in, or just stick 'em in there and they stay?
3. What is the best kind of foam insert that will allow the best combination of good handling and tire life?
4. Does the type ss take 26mm foam?
Old 05-18-2003 | 01:56 PM
Default Re: Foam inserts
well I can awsner your first two.
1. It is very possible but I wouldnt recommend it.
2. you dont have to clue them in.
Old 05-18-2003 | 04:12 PM
arent they coming out with the Rs4 4th generation soon?
check hpi's site maybe you can hodl off till it shows its face.
Old 05-18-2003 | 05:11 PM
What kind of foam insert is the best then?
