HPI Body fit on Tamiya DF-03Ra?
TX
Does anyone know if a 190mm HPI Subaru Impreza body will fit on a Tamiya DF03-Ra?
Wheel base on the DF-03Ra is 10.5 inches....not sure what wheel base is on the HPIbody...I think it's 10 inches
<h1 class="vi-is1-titleH1"></h1>
According to specs the stock lancer Tamiya body is 17.5" long and 6.9" wide. HPI Impreza is 17.5" long and 7.5" wide and that's for the 190mm body. You can make virtually any body fit anything you want although body modification and or chassis modifying may be needed.
So it looks like ya may be a little wide going with the HPI body. Wheelbase shouldn't be too much of a problem, I'd be more concerned about overall width of the body.
